Qualcosa bolle in pentola...
Here's a quick peak at SBrick Light, our smart lighting solution for LEGO sets and home art projects. Check out how it looks and get a feel for the size of this smart brick. You can add 8 different LED strands and then set these RGB LEDs to the color you want, it's easy. Here I show our first housing prototype that is not exactly how the final product looks, but is a close approximation. Check it out, and set your calendar from Friday!
Inserito (modificato)
Piccolo delay, slitta dal 8 Ottobre al 14 Ottobre il pre-order.
Over the past few weeks we’ve been having issues caused by Covid, no doubt we’re not alone in this but we hoped we’d be able to avoid any repercussions from the pandemic. But, due to Covid we have to delay the launch of SBrick Light until Wednesday 14 October.  In this video I talk a little bit about our manufacturing partner, Tungsram, and also tell you a little bit about the LEDs and cables/wires we’ll be using.
Ultima modifica: da Pix
Sistema LED di SBrick in pre-order:
Devo dire che la gestione delle luci negli ultimi anni è esponenzialmente esplosa.
SBrick presenta due modelli, uno SMALL e uno LARGE.
SBrick Light is available in normal and slim editions
Ecco qui il listino:
Se andate sulla pagina dello SHOP e cliccate sul modello, vedrete anche quante luci avete nel pacchetto:
https://www.sbrick.com/store
Peccato che non ci sia (o almeno non l'ho trovato) qualche dettaglio sulla dimensione dei LED.
